Hi All,
I’ve setup the Racid with the following document
My system is running on Ubuntu and NGINX with the following detail
=> cat /var/lib/rancid/.cloginrc
add user * xxxxx
add password * yyyyy
add method * telnet
add noenable * {1}
=> Rancid in config.php
$config[‘rancid_configs’][] = ‘/var/lib/rancid/librenms/configs/’;
$config[‘rancid_repo_type’] = ‘svn’;
$config[‘rancid_ignorecomments’] = 0;
I’ve test the command sudo /usr/lib/rancid/bin/clogin -f /var/lib/rancid/.cloginrc and it can telnet to devices as expected.
My problem is I can see the file of devices in /var/lib/rancid/librenms/configs/ but the file size is 0 and no configuration inside as below.
-rw-r----- 1 rancid rancid 0 Dec 15 14:23 10.196.102.1
-rw-r----- 1 rancid rancid 0 Dec 22 12:18 10.196.102.2
-rw-r----- 1 rancid rancid 0 Dec 22 12:18 10.196.102.3
-rw-r----- 1 rancid rancid 0 Dec 22 12:18 10.196.102.4
-rw-r----- 1 rancid rancid 0 Dec 22 12:18 10.196.102.5
How can I resolve this problem? Please kindly advice.
below is my ./validate.php
| LibreNMS | 1.70.1-35-g24604dd0e |
| DB Schema | 2020_11_02_164331_add_powerstate_enum_to_vminfo (191) |
| PHP | 7.4.3 |
| Python | 3.8.5 |
| MySQL | 10.3.25-MariaDB-0ubuntu0.20.04.1 |
| RRDTool | 1.7.2 |
| SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 2.0.8
[WARN] Your install is over 24 hours out of date, last update: Sat, 16 Jan 2021 00:48:51 +0000
