Hi!
I would like to ask for help.
https://p.libren.ms/view/f02ecc55
https://p.libren.ms/view/a1b9aa43
On Raspberry Pi 4, LIBRENMS runs on Raspbian OS.
It detects its own sensors, Voltage, Codec, Temperature, but not ARM frequencies.
SNMP Walk brings the values along with the frequency
snmpwalk -v2c -c public 192.168.1.200 NET-SNMP-EXTEND-MIB :: nsExtendOutLine
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .1 = STRING: 49.0
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .2 = STRING: 0.9500
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .3 = STRING: 1.1000
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .4 = STRING: 1.1000
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .5 = STRING: 1.1000
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .6 = STRING: frequency (48) = 1333652352
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .7 = STRING: frequency (1) = 357038080
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .8 = STRING: enabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .9 = STRING: disabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .10 = STRING: disabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .11 = STRING: disabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .12 = STRING: enabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .13 = STRING: disabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .14 = STRING: H264 = 2
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .15 = STRING: MPG2 = disabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .16 = STRING: WVC1 = disabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .17 = STRING: MPG4 = disabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .18 = STRING: MJPG = 2
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .19 = STRING: WMV9 = disabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .20 = STRING: H264 = enabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .21 = STRING: MPG2 = 1
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .22 = STRING: WVC1 = 1
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .23 = STRING: MPG4 = 1
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .24 = STRING: MJPG = enabled
NET-SNMP-EXTEND-MIB :: nsExtendOutLine. “Raspberry” .25 = STRING: WMV9 = 1
However, in the summary view, I don’t see the frequency under the gui.
What should I claim to work properly, it would be witty to see on certain runs how much it loads the cpu.
Thanks!
