I’ve added a new Raspberry PI device but can’t get the sensors to work.
The Voltage and Frequency doesn’t show on the device page.
The discovery shows the correct values:
Load disco module sensors
Pre-cache linux: RaspberryPi SNMP[[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -M /opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell udp:HOSTNAME:161 .1.3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121[0m]
iso..1.8....121.1 = “51.0”
iso..1.8*....121.2 = “1.3438”
iso..1.8*....121.3 = “1.2000”
iso..1.8*....121.4 = “1.2000”
iso..1.8*....121.5 = “1.2250”
iso..1.8*....121.6 = “1200002000”
iso..1.8*....121.7 = “400000000”
iso..1.8*....121.8 = “disabled”
iso..1.8*....121.9 = “disabled”
iso..1.8*....121.10 = “disabled”
iso..1.8*....121.11 = “disabled”
iso..1.8*....121.12 = “disabled”
iso..1.8*....121.13 = “disabled”
iso..1.8*....121.14 = “H264=disabled”
iso..1.8*....121.15 = “MPG2=disabled”
iso..1.8*....121.16 = “WVC1=disabled”
iso..1.8*....121.17 = “MPG4=disabled”
iso..1.8*....121.18 = “MJPG=disabled”
iso..1.8*....121.19 = “WMV9=disabled”
iso..1.8*....121.20 = “WMV9=disabled”
iso..1.8*....121.21 = “H264=1”
iso..1.8*....121.22 = “MPG2=1”
iso..1.8*....121.23 = “WVC1=1”
iso..1.8*....121.24 = “MPG4=1”
iso..1.8*....121.25 = “MJPG=1”
iso..1.8*...*.121.26 = “WMV9=1”Array
[raspberry_pi_sensors] => Array
[3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.1] => Array
[iso] => 51.0
)[3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.2] => Array ( [iso] => 1.3438 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.3] => Array ( [iso] => 1.2000 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.4] => Array ( [iso] => 1.2000 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.5] => Array ( [iso] => 1.2250 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.6] => Array ( [iso] => 1200002000 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.7] => Array ( [iso] => 400000000 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.8] => Array ( [iso] => disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.9] => Array ( [iso] => disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.10] => Array ( [iso] => disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.11] => Array ( [iso] => disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.12] => Array ( [iso] => disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.13] => Array ( [iso] => disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.14] => Array ( [iso] => H264=disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.15] => Array ( [iso] => MPG2=disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.16] => Array ( [iso] => WVC1=disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.17] => Array ( [iso] => MPG4=disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.18] => Array ( [iso] => MJPG=disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.19] => Array ( [iso] => WMV9=disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.20] => Array ( [iso] => WMV9=disabled ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.21] => Array ( [iso] => H264=1 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.22] => Array ( [iso] => MPG2=1 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.23] => Array ( [iso] => WVC1=1 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.24] => Array ( [iso] => MPG4=1 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.25] => Array ( [iso] => MJPG=1 ) [3.6.1.4.1.8072.1.3.2.4.1.2.9.114.97.115.112.98.101.114.114.121.26] => Array ( [iso] => WMV9=1 ) ))
| LibreNMS | 1.43-40-gaf7539ff3 |
| DB Schema | 265 |
| PHP | 7.2.7-0ubuntu0.18.04.2 |
| MySQL | 5.7.23-0ubuntu0.18.04.1 |
| RRDTool | 1.7.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.2
Discovery: Untitled - LibreNMS
Poller: Untitled - LibreNMS
