Just to recap, I only see graphs for codecs, no voltage graphs are displaing. Here is the discovery output requested: https://pastebin.com/L5qzmm3D
Thanks again!
Thanks again!
I tried reverting back to the commit mentioned in some previous post. LibreNMS looked different back then. All sensors were removed from the device on discovery, so I reverted back. Now I have two CPU temp for one of the pi’s
Any ideas? I’ve messed up the sensors on one of the pi’s, it now has two temperature sensors, both with the same data… Re-discovery doesn’t seem to resolve it.
@mirino75 @mwen Is your libreNMS install still showing correct values/sensors?
I’ve tried reverting back, but I think the build is too old, maybe you guys can point us in the right direction?
So, a new patch is live, and after changing raspberry.sh like mentioned in the patch, I see new sensors.
However, on both installs, it’s reporting back 0 as value.
Same boat here, updated the script and I get all zeros. Here is the output of my snmp walk, is the output of the snmpwalk correct, should it be one long quoted string like this? I noticed in the past each sensor got its own OID string (like a tree), sorry I am not an expert in snmp verbage. Any how hope it helps, Thanks again for all the help on this!
$ snmpwalk -v2c -c public picam iso.3.6.1.4.1.8072.1.3.2.3.1.2.9.114.97.115.112.98.101.114.114.121
iso.3.6.1.4.1.8072.1.3.2.3.1.2.9.114.97.115.112.98.101.114.114.121 = STRING: “48.7
1.2000
1.2000
1.2000
1.2250
700000000
250000000
enabled
disabled
disabled
enabled
enabled
WMV9=disabled
H264=2
MPG2=disabled
WVC1=disabled
MPG4=2
MJPG=2
WMV9=disabled
WMV9=disabled
H264=enabled
MPG2=1
WVC1=1
MPG4=enabled
MJPG=enabled
WMV9=1”
We need:
./discovery.php -h HOSTNAME -d -m sensors
./poller.php -h HOSTNAME -d -m sensors -r -f
Here you go:
discovery: https://pastebin.com/A4EN9NLC
poller: https://pastebin.com/r2BsJygd
Please try this patch: https://gist.github.com/laf/b6d2c4ecbb86e6737d77127f562d678d
No love, here is a new round of output:
discovery: https://pastebin.com/GT8FLmct
poller: https://pastebin.com/LULk0mn7
Try reverting the agent script to the previous version
I reverted the patch and changed the snmp extend script, still no luck. Also just so you know, though all of this I have always got the temperature reading in my graphs.
Here is the latest output:
discovery: https://pastebin.com/jbJWvtaH
poller: https://pastebin.com/qH0TYyXk
Yep, same here … temperature is working, but the rest are broken now. FYI, this used to work on my machine.
Thanks!
No just the snmp extend script that needs reverting to the one I linked to. You should be running latest master for LibreNMS core.
Yep, running the latest LibreNMS core (updated this morning, just to make sure). And the extend script … you mean raspberry.sh, that is called from snmpd on the client (RPi), right? That’s what I updated.
Sorry about that, I just re-applied the patch, and reverted to the older snmp extend script. No luck
Discovery: https://pastebin.com/2GZx6KeX
Poller: https://pastebin.com/uRYRhaNW
If someone wants to provide:
snmpbulkwalk -OUneb -v2c -c COMMUNITY HOSTNAME . | ./pbin.sh
Then we can take more of a look.
Here ya go, this is inclusive of the changes requested above (patch and reverted snmpd script).
librenms@velocity:~$ ./discovery.php -h picam.qantum.lan -d | ./pbin.sh
Paste endpoint: https://p.libren.ms/api/create
title:
private: 1
expire: 0
https://p.libren.ms/view/6f25317b
librenms@velocity:~$ ./poller.php -h picam.quantum.lan -r -f -d | ./pbin.sh
title:
private: 1
expire: 0
https://p.libren.ms/view/889baa11
librenms@velocity:~$ snmpbulkwalk -OUneb -v2c -c public picam.quantum.lan . | ./pbin.sh
title:
private: 1
expire: 0
https://p.libren.ms/view/6e553444
| LibreNMS | 1.30-36-g4e56ee17b |
| DB Schema | 199 |
| PHP | 7.1.6-2ubuntu1 |
| MySQL | 10.1.24-MariaDB-5 |
| RRDTool | 1.6.0 |
| SNMP | NET-SNMP 5.7.3 |
https://p.libren.ms/view/10ee04f7
https://p.libren.ms/view/f9f9b269
https://p.libren.ms/view/1499d62a
Reverted raspberry.sh to the one you linked and am running the latest master without any patches.
@cweakland you made a typo in the first command ![]()
The host is not found ![]()
Fixed in: https://github.com/librenms/librenms/pull/7131
Will merge once checks are done.
