It is the summary of the 3 (by default) that are sent together every poll. There are entries for every poll, so , no it is not aggregated over time, only within each distinct attempt.
If you want “raw” results set ping attempts to 1 (this is a dumb idea).
I would had thought you could easily get the raw data. The big reason i am asking for the raw data is I can see in quite a number of polls where Avg is less than Min which is wrong and the analysis I am doing requires a high degree of accuracy.
Would setting Ping Attempts = 2 achieve the same result?
If you have avg,min,max at all it is an aggregate/summary. But it is only for that one poll.
So, here is how it works:
Poll #1:
fping -c 3 pings 3 times then returns:
xmt/rcv/%loss = 3/3/0%, min/avg/max = 0.020/0.023/0.027
Librenms records that data
Poll #2:
xmt/rcv/%loss = 3/3/0%, min/avg/max = 0.020/0.024/0.030
So, as you can see, it is only the data from fping for each poll being recorded. LibreNMS does no calculation on the data. Simply stores it.
