Re-enabling Proxmox
I broke my Proxmox install and had to re-install everything. I installed the agent per:
After install, from the LibreNMS server:
librenms@librenms:~$ telnet 10.1.2.3 6556 | grep -i ubuntu
100/net0/52516442758/2181799750566/ubuntuVM
100/net1/2465933092902/327368092571/ubuntuVM
Connection closed by foreign host.
So the server can see lots of data on that port, but the LibreNMS GUI shows a ? (Unknown State) Proxmox under Apps. Other apps work.
No changes were made to the LibreNMS setup.
Is there anything that needs to be reset in LibreNMS like a UID that got reset? All other information is still there and working.
$ ./validate.php
LibreNMS 22.7.0-14-ga214dbc8f
DB Schema 2022_07_03_1947_add_app_data (244)
PHP 7.4.3
Python 3.8.10
MySQL 10.3.34-MariaDB-0ubuntu0.20.04.1
SNMP 5.8
[OK] Composer Version: 2.3.10
[OK]
[OK] MySQl and PHP time match
