Would be cool to have a button under this tap that allows for reboot of Cisco devices using SNMP.
this feature would be extremely handy in cases where SSH/Telnet becomes unresponsive when CPU spikes or memory leak occurs but SNMP is still alive
If this is implemented, it needs safeguards to prevent accidental restarts.
LibreNMS currently ties into Radius (ISE in our case) - ensure Security and Roles are properly defined, ensure logging is enabled and you should not have a problem with this - so yeah agree can add that button should only appear if you have admin rights
Personaly think that before that the user roles need to be overhauled. Like we have admins i dont want to have an option to reboot any device. But i do want them to add customer routers to our pollers them selves. So they need an admin role currently. If there where options to create custom group roles maybe even based on device groups.
Besides that reboots if needed are troubleshooted much deeper librenms would tell us so any admin is allready logged in to the device.
