Recreate rrdfile
I accidentally deleted some “mempool.rrd” files in rrdcached db dir. how can i find the correct "rrdtool
create… " command ?
Regards
Hi @Marc_Boisis
LibreNMS will regenerate them after next poll. So you don’t have anything to do.
Bye
the poller does not recreate the file :
poller.php -h 19 -v
#### Load poller module mempools ####
SNMP['/usr/bin/snmpget' '-v2c' '-c' 'public' '-OUQn' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/hp' 'udp:sw42busr.univ-lr.fr:161' '.1.3.6.1.4.1.11.2.14.11.5.1.1.2.1.1.1.7.1' '.1.3.6.1.4.1.11.2.14.11.5.1.1.2.2.1.1.7.1']
hpLocal [system]: Local Memory 1: 21%  10.14 MiiB / 47.85 MiiB
RRDtool Output: OK u:0.01 s:0.00 r:4.35
hpGlobal [system]: Global Memory 1: 21%  10.14 MiiB / 47.85 MiiB
RRDtool Output: ERROR: [email protected]:42217: No such file: /data/db/sw42busr.univ-lr.fr/mempool-hpLocal-system-1.rrd
>> Runtime for poller module 'mempools': 0.0617 seconds with 36640 bytes
>> SNMP: [1/0.04s] MySQL: [0/0.00s] RRD: [3/0.00s]
#### Unload poller module mempools ####
RRDtool Output: ERROR: [email protected]:42217: No such file: /data/db/sw42busr.univ-lr.fr/mempool-hpGlobal-system-1.rrd
It does when rrdcached is configured properly or when rrdcached is not installed at all. Seems that your rrdcached is broken.
You should check the docs and fix it.
It works, I forgot
$config[‘rrdtool_version’] = ‘1.7.2’;
thanks
