Dejan
26 March 2020 20:36
1
Is it possble to reference a device by its name from external system?
URL usually looks like this “http://librenms/device/device=22 ”
Is it possible to do it like “http://librenms/device/myswitch ” ?
I tested it and it does not throw an error but there is no any info displayed.
Have you tried the sysname or the host name?
Documentation says you can/should be able to.
https://docs.librenms.org/API/Devices/
Dejan
27 March 2020 08:59
5
Yes, that.s correct but i’m not trying to do this through API but straight to WebUI.
i tried it in Browser with hostname and it was successfully.
Eventually you’ve to transport login information with it, if you’re not logged in
Dejan
31 March 2020 08:23
7
That’s great to hear. I’m logged in while trying. Would you be kind and share what your URL looks like when performing test?
this is what i use and it doesnt work
http://librenms/device/kbg10-accs-sw-01
have you tried FQDN like it’s shown?
Dejan
31 March 2020 08:26
9
If you mean http://librenms.domain.com/device/kbg10-accs-sw-01 then yes. I’m just not desplaying it for security reasons.
Dejan
31 March 2020 08:28
10
This is what it looks like.
do you use Release Version oder daily synct Version?
have you tried a hostname different to “kbg10-accs-sw-01”.
I have no “-” in it. Also not sure if this character is officially allowed in a hostname/FQDN. I tested it with a myhostname.my.own.domain structure containing only a-z and 0-9, and it works well.
Dejan
31 March 2020 09:15
15
Now…that tip made a difference. Together with post before. Instead of changing hostname i used ip-address and it worked
http://librenms.domain.com/device/device=10.2.2.5
Dejan
16 May 2020 08:59
16
Hello again!
Has anything been changed in regard to this topic? This doesn’t work anymore.
This time i get “404 not found”
Dejan
17 May 2020 21:04
17
URL has definitely been changed. No more “device=” Its straightforward librenms.domain.com/device/id
I’m not able to link directly to a device via URL by hostname nor sysname. Only ID works.
I used to do this from Netbox via custom link. I use Netbox as inventory source
I am having the same problem.
How should I deal with it?
It seems this was removed ;(
Good news everyone, new version is under development so this feature will come back probably in next release
