Removing device direct link
I would like to remove the “direct link” for ssh/telnet/web for devices.
I cannot find any configuration for this.
Capture can still be applicable for me, but the other devices arent usable since we are using an external jumphost, so I want to remove them completely.
It this possible without changing the sourcecode, that might hinder the updates.
Cant say that the template with validate is applicable in this case.
Not possible currently, as you noticed.
Feel free to create a pull request with your changes for this feature. You would have to create a new config option for each of those protocols.
Bye
