So, basically, I have some empty power supply modules that are triggering this alert.
I’ve attempted to have:
sensors.sensor_descr NOT LIKE ‘%NotExist%’
after going into the DB and noticing each id in question looked like
Sw1, PS1 Normal, RPS NotExist
Switch 1 - Power Supply B, NotExist
After that failed, I noticed each sensors_to_state_indexes.state_index_id = 9, but even carving that out didn’t stop it from populating the usual suspects.
Invert rule match is disabled.
