I stood up a vanilla LibreNMS on an Ubuntu Server. It worked great.
In my multi-month hiatus/absence, another colleague attempted to install Oxidized, and failed.
Now that I am back, I am receiving errors and the NMS is behaving erratically.
In an attempt to keep from rebuilding the entire NMS and its device database/rules/etc…, I would like to try and gracefully turn off whatever was turned on by Oxidized and gracefully remove whatever was installed for it.
Then later on, I would like to try installing Oxidized myself, but that is for a later time. I just want the NMS back to normal if possible.
Can someone tell me how to remove Oxidized from LibreNMS (completely). I assume the user installed from repositories and not from a GitHub source build.
Thanks in advance
