When using renamehost.php the objects get correctly renamed in the DB. But RRDCached is not notified. This causes the following errors when the poller tries to update the graphs;
Feb 16 11:05:04 xxx rrdcached[2530468]: queue_thread_main: rrd_update_r (/opt/librenms/rrd/xxx/port-id397638.rrd) failed with status -1. (opening '/opt/librenms/rrd/xxx/port-id397638.rrd': No such file or directory)
Feb 16 11:05:04 xxx rrdcached[2530468]: queue_thread_main: rrd_update_r (/opt/librenms/rrd/xxx/port-id397639.rrd) failed with status -1. (opening '/opt/librenms/rrd/xxx/port-id397639.rrd': No such file or directory)
Feb 16 11:05:04 xxx rrdcached[2530468]: queue_thread_main: rrd_update_r (/opt/librenms/rrd/xxx/port-id399407.rrd) failed with status -1. (opening '/opt/librenms/rrd/xxx/port-id399407.rrd': No such file or directory)
Feb 16 11:05:04 xxx rrdcached[2530468]: queue_thread_main: rrd_update_r (/opt/librenms/rrd/xxx/port-id399408.rrd) failed with status -1. (opening '/opt/librenms/rrd/xxx/port-id399408.rrd': No such file or directory)
Feb 16 11:05:04 xxx rrdcached[2530468]: queue_thread_main: rrd_update_r (/opt/librenms/rrd/xxx/port-id399409.rrd) failed with status -1. (opening '/opt/librenms/rrd/xxx/port-id399409.rrd': No such file or directory)
Feb 16 11:05:04 xxx rrdcached[2530468]: queue_thread_main: rrd_update_r (/opt/librenms/rrd/xxx/port-id399410.rrd) failed with status -1. (opening '/opt/librenms/rrd/xxx/port-id399410.rrd': No such file or directory)
Feb 16 11:05:04 xxx rrdcached[2530468]: queue_thread_main: rrd_update_r (/opt/librenms/rrd/xxx/port-id431643.rrd) failed with status -1. (opening '/opt/librenms/rrd/xxx/port-id431643.rrd': No such file or directory)
This issue is resolved when restarting RRDCached. So this issue might be fixed by sending a notify to RRDCached upon renaming a device.
Setup;
LibreNMS | 21.1.0
DB Schema | 2020_10_12_095504_mempools_add_oids (191)
PHP | 7.3.20
Python | 3.6.8
MySQL | 10.3.17-MariaDB
RRDTool | 1.7.0
SNMP | NET-SNMP 5.8
