Can I disable the discovery worker for a device?
The reason is, I have a device that repeatedly loses and then regains some sensors. As a result, I keep losing my own settings (warning levels).
Or is this caused by something else?
I don’t think this is due to my LibreNMS installation. I have the same problem with similar devices. Many others work perfectly fine.
Here is the event Log:
| Timestamp | Type | Hostname | Message | User |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.1 Ambient | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.2 Systemboard | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.3 CPU1 | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.4 CPU2 | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.5 MEM A | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.6 MEM B | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.7 MEM C | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.8 MEM D | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.9 MEM E | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.10 MEM F | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.11 MEM G | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.12 MEM H | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.13 PCH | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.14 LOM | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.15 PSU1 Inlet | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.16 PSU2 Inlet | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.17 PSU1 | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.18 PSU2 | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.19 BBU | System |
| 2024-06-25 02:02:24 | sensor | srv146 | Sensor Added: temperature fujitsuiRMC 1.20 RAID Controller | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.3 CPU1 | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.4 CPU2 | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.5 MEM A | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.6 MEM B | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.7 MEM C | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.8 MEM D | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.9 MEM E | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.10 MEM F | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.11 MEM G | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.12 MEM H | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.13 PCH | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.14 LOM | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.15 PSU1 Inlet | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.16 PSU2 Inlet | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.17 PSU1 | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.18 PSU2 | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.19 BBU | System |
| 2024-06-24 20:02:11 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.20 RAID Controller | System |
| 2024-06-24 20:02:10 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.1 Ambient | System |
| 2024-06-24 20:02:10 | sensor | srv146 | Sensor Deleted: temperature fujitsuiRMC 1.2 Systemboard | System |
Thanks.
