Reverse Proxy Help/Documentation Conflict
I was having trouble getting a reverse proxy to work, the main issue seemed to be that I wanted it at www.example.com/librenms/ and not at the root.
I followed the FAQ section for “My reverse proxy is not working” by verifying that I was passing the correct headers, configuring the proxy as a trusted proxy, and setting $config['base_url'] and APP_URL, but it still didn’t work.
config.php:
$config["base_url"] = 'https://www.example.com/librenms/';
.env:
APP_TRUSTED_PROXIES=192.168.1.30
APP_URL=https://www.example.com/librenms/
What did work was changing the native librenms url following this: Sub-directory Support - LibreNMS Docs but there seems to be some conflicting advice there. That document says:
The RewriteBase directive in html/.htaccess must be rewritten to reference the subdirectory name.
but html/.htaccess says:
DO NOT CHANGE THIS FILE
If you need to change this file, you are doing something wrong.
It only seems to work if I change the file. What should I do?
change .htaccess
I’m glad to hear that I’m not doing something wrong :slight_smile:
Will this break updates if there’s a git commit that changes that file?
The project tries not to change that file because many people use subdirectories…
I personally prefer using sub-domains, much cleaner.
Depending on your DNS and Certificate setup that could certainly be the case.
Thanks so much for the quick response!
Let’s Encrypt for the win :wink:
