DO NOT DELETE THIS INFORMATION.
Please confirm each of the sections below by putting an x in the box like [x].
- [x] Is your install up to date? Updating your install
Please do not submit an issue if your install is not up to date within the last 24 hours or on a stable monthly release. - [x] Please include all of the information between the
====================================section of./validate.phpwhich you can run from the cli. - [x] Please provide ALL info asked for here.
- [x] Please provide as much detail as possible.
- [x] Please do NOT post more than 10 lines of debug information here, use a pastebin service or GitHub Gists.
| LibreNMS | 4ef0a2d719b54ad1e8f1666667763cb99248dbd1 |
| DB Schema | 163 |
| PHP | 7.0.13-0ubuntu0.16.10.1 |
| MySQL | 10.0.29-MariaDB-0ubuntu0.16.10.1 |
| RRDTool | 1.6.0 |
| SNMP | NET-SNMP 5.7.3 |
Discovery:
Poller:
Snmpbulkwalk:
Please add this informations:
.1.3.6.1.4.1.367.3.2.1.7.2.3.8.0 = Product number
.1.3.6.1.4.1.367.3.2.1.2.19.1.0 = Printer + Copier
.1.3.6.1.4.1.367.3.2.1.2.19.2.0 = Printer Black & White
.1.3.6.1.4.1.367.3.2.1.2.19.3.0 = Fax Black & White
.1.3.6.1.4.1.367.3.2.1.2.19.4.0 = Copier Black & White
.1.3.6.1.4.1.367.3.2.1.2.19.5.1.9.27 = Scanner Send
.1.3.6.1.4.1.367.3.2.1.2.19.5.1.9.28 = Fax Transmission
.1.3.6.1.2.1.43.16.5.1.2.1.1 = “Niveau bas : Toner”
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.1 = -100 (Empty toner) / 100 full
