So I have rrd stored on a remove server. It was working fine untill about 3 weeks ago and now im getting gaps in the graps. Any help would be great
You’re really not giving us much to go with here. Output of validate? Have you check any log files including the LibreNMS one?
./validate.php
| LibreNMS | 23.11.0-12-g3be233af5 (2023-11-29T17:18:26-05:00) |
| DB Schema | 2023_11_21_172239_increase_vminfo.vmwvmguestos_column_length (274) |
| PHP | 8.1.2-1ubuntu2.14 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.6.5
[OK] MySQl and PHP time match
[FAIL] Some dispatcher nodes have not checked in recently
Inactive Nodes:
csp-lnms-srv01********* (this node)
[OK] Redis is functional
i know about the dispatcher… i dont have the server doing polling… i have other servers for that
I’m more of a consumer of the setup in question, but can add some more detail on the setup:
We have a number of VMs dedicated to various tasks for librenms:
MariaDB & rrd storage: 8core, 16G
nginx librenms web interface: 4core, 8G
pollers: 2x (16core, 8G) [2 more pollers were added yesterday with no change in the graphing issue]
We have roughly 1200 devices / 200,000 ports.
Pollers have 52 workers each and prior to adding the additional pollers yesterday, only used about 20% of their available worker seconds. With the additional pollers, they’re only using about 10% of the available worker seconds.
Poller Cluster Health shows a relatively even split of devices actioned per poller, no devices pending, yet we have a large number of what we’re calling “zebra graphs” [graphs like the one above, or worse, in which there are missing samples in the RRDs]. Some of our graphs look fine. Others are consistently missing data. This suggests to me that in each poller run, some devices are not getting data into their rrds…but poller health page says everything is fine.
Our poller librenms.log files are full of
ErrorException: mkdir(): Permission denied in /opt/librenms/LibreNMS/Poller.php:247
This is from the mkdir in initRrdDirectory failing…and it seems to me this is a bug, as the poller shouldn’t be bothering trying to mkdir($host_rrd) to initialize an rrd directory if rrdcached is in use.
Try upping your mysql connections? I had gaps in my graphs too and by upping to 1000 connections it fixed it.
[mariadb]
max_connections=1000
added to:
/etc/my.cnf.d/server.cnf
You can also check mysql connections: show status like ‘%onn%’;exit
and look for aborted connections.
so these are in RRD not sql and our connection max is at 5k right now.
