kdavid
5 December 2023 13:42
1
Hi all,
is there any easy way to miggrate from rrd to grafana in librenms? Also any way to keep smart graph popups? Some simple elegant way?
I found this: GitHub - doublemarket/grafana-rrd-server: A HTTP server that helps Grafana read RRD files via Grafana Simple JSON Datasource plugin
but i dont know if it is what i need. I need to monitor 2000+ devices so idk which is the best way. We dont want to use grafana as separate system. Ideal will be to have all in one in librenms as it is now.
Thank you
BR
Dave
Enable influxdb output and use that for grafana datasource - InfluxDB - LibreNMS Docs
There is no way to switch the metrics datastore used by LibreNMS from RRD files to another time series database currently.
system
Closed
4 March 2024 22:29
3
