I am having an issue with rrdcached when converting RRD files from 5min interval to 2min interval. My steps have been to stop rrdcached sevice, update polling interval in web gui, run ./scripts/rrdstep.php -h all
, then start rrdcached again. Shortly after rrdcached starts, it crashes - logs from /var/log/messages below.
When I attempt to re-convert rrd graphs, I get below rrd errors for every graph on every device, and the “floating point exception” is logged is syslog again as well.
Any one know if 2 minute polling is supported? This page is for 1 minute polling, but it suggests that any interval can be used: https://docs.librenms.org/#Support/1-Minute-Polling/
Errors from /var/log/messages when rrdcached crashes and while converting:
Converting /opt/librenms/rrd/172.16.0.170/ping-perf.rrd: sh: line 4: 13806 Floating point exception/usr/bin/rrdtool dump /opt/librenms/rrd/1AIL]6.0.170/ping-perf.rrd > /tmp/1914598963.xml
Error to stdout while rrdstep.php is converting:
Aug 6 19:01:41 librenms01 kernel: traps: rrdtool[6575] trap divide error ip:7ff5f724534e sp:7fff4645d5b0 error:0 in librrd.so.8.0.0[7ff5f7239000+6a000]
