RRDcached help on pollers running in Docker
Hello
I’ve set RRDcach up on our main LibreNMS server using:
Now I need to do the same on the 2 pollers we use which are running in Docker, I can’t seem to find documentation on how to do this?
Do I just use the link above and do the same outside of Docker, or do I need to use the Docker COmpose yml file etc?
Distributed pollers must send their collected rrd’s to frontend server rrdcached.
As i understand rrdcached can’t scale its a single instance solution.
