I’ve performed a clean install of libreNMS on Ubuntu 22.04
I’ve then migrated the database over from a libreNMS Centos 7 install and copied over rrd files.
Unfortunately the rrd files don’t appear to be getting updated when I enable rrdcached. Note. Disabling rrdcached and everything is OK.
Running poller.php on a device doesn’t rectify this either. If I erase rrd/DEVICE folder then run poller.php on said device, it will create the folder and files. However, it doesn’t continue to update. Similar happens if I add a new device.
Polling is definitely happening as device alerts etc are updating.
I’ve set permissions and confirmed.
chown -R librenms:librenms /opt/librenms
chmod 771 /opt/librenms
setfacl -d -m g::rwx /opt/librenms/rrd /opt/librenms/logs /opt/librenms/bootstrap/cache/ /opt/librenms/storage/
setfacl -R -m g::rwx /opt/librenms/rrd /opt/librenms/logs /opt/librenms/bootstrap/cache/ /opt/librenms/storage/
chown librenms:librenms /var/lib/rrdcached/journal/
Am I missing something obvious?
| LibreNMS | 23.2.0-43-gae429d987 (2023-03-22T01:31:42+13:00) |
| DB Schema | 2023_03_14_130653_migrate_empty_user_funcs_to_null (249) |
| PHP | 8.1.2 |
| Python | 3.10.4 |
| Database | MariaDB 10.6.7-MariaDB-2ubuntu1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.5.4
[OK] MySQl and PHP time match
librenms@librenms:~$
config.php
<?php
## Have a look in defaults.inc.php for examples of settings you can set here. DO NOT EDIT defaults.inc.php!
### Database config
$config['db_host'] = 'localhost';
$config['db_user'] = 'librenms';
$config['db_pass'] = 'XXXXXXXXXXXX';
$config['db_name'] = 'librenms';
$config['db']['extension'] = "mysqli";// mysql or mysqli
// This is the user LibreNMS will run as
//Please ensure this user is created and has the correct permissions to your install
$config['user'] = 'librenms';
### Memcached config - We use this to store realtime usage
$config['memcached']['enable'] = FALSE;
$config['memcached']['host'] = "localhost";
$config['memcached']['port'] = 11211;
### Locations - it is recommended to keep the default
$config['install_dir'] = "/opt/librenms";
### This should *only* be set if you want to *force* a particular hostname/port
### It will prevent the web interface being usable form any other hostname
#$config['base_url'] = "http://librenms.company.com";
### Enable this to use rrdcached. Be sure rrd_dir is within the rrdcached dir
### and that your web server has permission to talk to rrdcached.
$config['rrdcached'] = "unix:/run/rrdcached.sock";
### Default community
$config['snmp']['community'] = array("public");
$config['autodiscovery']['xdp'] = TRUE;
### Authentication Model
$config['auth_mechanism'] = "mysql"; # default, other options: ldap, http-auth
#$config['http_auth_guest'] = "guest"; # remember to configure this user if you
### List of RFC1918 networks to allow scanning-based discovery
#$config['nets'][] = "10.0.0.0/8";
#$config['nets'][] = "172.16.160.0/20";
# following is necessary for poller-wrapper
# poller-wrapper is released public domain
$config['poller-wrapper']['alerter'] = FALSE;
# Uncomment the next line to disable daily updates
#$config['update'] = 0;
#useful as we don't have dns records for most
$config['force_ip_to_sysname'] = true;
#ignore mikrotik WDS clients
$config['bad_if_regexp'][] = '/^wds[0-9]/';
$config['snmp']['timeout'] = 2; # timeout in seconds
$config['snmp']['retries'] = 5; # how many times to retry the query
$config['fping_options']['retries'] = 5;
$config['fping_options']['timeout'] = 1000;
$config['poller_modules']['ipmi'] = 0;
$config['poller_modules']['ospf'] = 0;
$config['poller_modules']['applications'] = 0;
$config['poller_modules']['mpls'] = 0;
/etc/default/rrdcached
# Where database files are placed. If left unset, the default /tmp will
# be used. NB: The daemon will reject a directory that has symlinks as
# components. NB: You may want to have -B in BASE_OPTS.
#BASE_PATH=/var/lib/rrdcached/db/
BASE_PATH=/opt/librenms/rrd/
# Where journal files are placed. If left unset, journaling will
# be disabled.
#JOURNAL_PATH=/var/lib/rrdcached/journal/
# FHS standard placement for process ID file.
#PIDFILE=/var/run/rrdcached.pid
PIDFILE=/run/rrdcached.pid
# FHS standard placement for local control socket.
#SOCKFILE=/var/run/rrdcached.sock
SOCKFILE=/run/rrdcached.sock
# Optional override group that should own/access the local control
# socket
#SOCKGROUP=root
# Optional override access mode of local control socket.
#SOCKMODE=0660
# Optional unprivileged group to run under when daemon. If unset
# retains invocation group privileges.
#DAEMON_GROUP=_rrdcached
DAEMON_GROUP=librenms
# Optional unprivileged user to run under when daemon. If unset
# retains invocation user privileges.
#DAEMON_USER=_rrdcached
DAEMON_USER=librenms
# Network socket address requests. Use in conjunction with SOCKFILE to
# also listen on INET domain sockets. The option is a lower-case ell
# ASCII 108 = 0x6c, and should be repeated for each address. The
# parameter is an optional IP address, followed by an optional port with
# a colon separating it from the address. The empty string is
# interpreted as "open sockets on the default port on all available
# interfaces", but generally does not pass through init script functions
# so use -L with no parameters for that configuration.
#NETWORK_OPTIONS="-L"
# Any other options not specifically supported by the script (-P, -f,
# -F, -B).
#BASE_OPTIONS="-B"
BASE_OPTIONS="-B -F -R"
poller results
https://p.libren.ms/view/9b008a78
