I just have a question that hopefully one of the kind folks here can answer. I have the latest Librenms package installed on Ubuntu 22.10. It is running fine, and I do not seem to have any issues. I was thinking of enabling “Fast Ping”. The documentation refers to rrdcahed by stating “If you are using” and “If Applicable”. So, my question is, do I need rrdcached to use Fast Ping? The documentation seems to make the assumption it is installed. So, I am confused as to whether I need it or not. I believe I am just using the standard cron poller rather than distributed.
Component | Version |
LibreNMS | 23.2.0-46-gd508d2d6f (2023-03-30T15:04:06-04:00) |
DB Schema | 2023_03_14_130653_migrate_empty_user_funcs_to_null (249) |
PHP | 8.1.7-1ubuntu3.3 |
Python | 3.10.7 |
Database | MariaDB 10.6.12-MariaDB-0ubuntu0.22.10.1 |
RRDTool | 1.7.2 |
SNMP | 5.9.3 |
