| LibreNMS | 1.46-40-g8bddfe722 |
| DB Schema | 273 |
| PHP | 7.2.10-0ubuntu0.18.04.1 |
| MySQL | 10.1.34-MariaDB-0ubuntu0.18.04.1 |
| RRDTool | 1.7.0 |
| SNMP | NET-SNMP 5.7.3 |
hello ,
according to “Setting up RRDCached” article rrdcached supports creating rrd files over rrdcached. i did every single step on “Distributed Poller” article but i could not manage get rrd graphs running. it always gives me “error drawing graph” error.
if i choose/add nfs server-client method to my servers everything goes back to normal.
but article says sharing file system is not required anymore!! i dont get it
here is my config
rrd server ( libre is not installed - memcached and rrdcached installed )
DAEMON=/usr/bin/rrdcached
DAEMON_USER=librenms
DAEMON_GROUP=librenms
WRITE_TIMEOUT=1800
WRITE_JITTER=1800
BASE_PATH=/opt/librenms/rrd/
JOURNAL_PATH=/var/lib/rrdcached/journal/
PIDFILE=/run/rrdcached.pid
SOCKFILE=/run/rrdcached.sock
SOCKGROUP=librenms
NETWORK_OPTIONS="-L"
BASE_OPTIONS="-B -F -R"
POLLER SERVER (libre installed)
$config[‘distributed_poller_name’] = php_uname(‘n’);
$config[‘distributed_poller_group’] = ‘0’;
$config[‘distributed_poller_memcached_host’] = “192.168.1.97”;
$config[‘distributed_poller_memcached_port’] = 11211;
$config[‘distributed_poller’] = true;
$config[‘rrdtool_version’] = ‘1.7.0’;
$config[‘rrdcached’] = “192.168.1.97:42217”;
$config[‘update’] = 0;
WEB SERVER ( libre is installed )
