I have two icx-7750 switches, and everything was graphing fine until recently. Now both switches show no ports. I deleted one a rediscovered it and still no ports. If I snmpwalk or use mrtg I can see the ports.
Anyone have any ideas on how to make the ports show up?
Without more information, it will be difficult. Could you start with ./validate.php
and ./discovery.php -h <deviceid> -v
? That should give us hints.
I may have found the problem. Running ./discovery.php -h <deviceid> -v
gives the following.
Load disco module ports
SNMP[’/usr/bin/snmpbulkwalk’ ‘-Cr50’ ‘-v2c’ ‘-c’ ‘public’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/brocade’ ‘udp:172.16.233.4:161’ ‘ifDescr’]
Timeout: No Response from udp:172.16.233.4:161
SNMP[’/usr/bin/snmpbulkwalk’ ‘-Cr50’ ‘-v2c’ ‘-c’ ‘public’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/brocade’ ‘udp:172.16.233.4:161’ ‘ifName’]
SNMP[’/usr/bin/snmpbulkwalk’ ‘-Cr50’ ‘-v2c’ ‘-c’ ‘public’ ‘-OQUs’ ‘-m’ ‘IF-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/brocade’ ‘udp:172.16.233.4:161’ ‘ifAlias’]
ifAlias.1 =
if I change -Cr50 int the snmpbulkwalk to 37 or lower it works and will show ports.
Where do I change -Cr50 in the config or can I change it?
Set max repeaters to 30 an it seems to work. I don’t understand what I did, but it works.
