Ruckus Neighbours seem loop?
But Local Port ,Remote Port are smae.
Is this possible?
Or just librenms Icon not supported to show?
Please help answer. Thank you.
I remember seeing that before here on the forums…I dont remember what the answer was. Have you searched around?
Yes, but also not understand.
Is it from you asked?
https://community.librenms.org/t/ignore-loop-back-ports/1044
http://docs.librenms.org/Support/Configuration/#interfaces-to-be-ignored
So, it just librenms mistake?
