I am new on librenms, I was able to setup the server and create maps with weathermap, however I would like to have weathermapper to build the network topology without me to have to build it manually (adding nodes, links, etc.).
I have installed weathermapper and is enabled in the librenms GUI, I can create the map and see it in the conf.d folder how but when I run from CLI it does not do anything.
I run php myweathermapper.php and it does nothing.
Can someone support me on this please so weathermapper can build the network topology automatically please?
Thank you.
