I’m just playing around with the network built in but I cannot get the map saving the coordinates of the nodes.
I enabled the edit node, unchecked the dynamic and pulled some devices into place.
But it doesn’t store it.
Someone know how to make the location permanent?
Which map are you talking about the Worldmap? or network map?
World map you can set the device using the device over ride location, physical address or coordinates.
Network Map unfortunately you cant edit/save those maps.
Talking about the network map.
So no way to draw a map that makes sense?
Because this view is pretty useless
You can edit the view settings, you need to save the config out put to your librenms config.php But yeah no way to arrange and save it. The code for it needs a lot of TLC.
