I’m getting dayly notification with the following error, please advise how to solve it?
Error: Daily update failedThe daily update script (daily.sh) has failed. Please check output by hand. If you need assistance, visit the LibreNMS Website to find out how.
By running it’s manually, it fails on the following:
[root@dl1-librenms-srv01 librenms]# ./daily.sh
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
./daily.sh
Unable to open logfile ‘/var/log/zarafa/php-mapi.log’ as user 'librenms’
Not enough permissions to append logfile ‘/var/log/zarafa/php-mapi.log’. Reverting to stderr.
Updated from f7e14df90e1eac5efedb0d52b482a911317cc791 to ec72eb2960db383948d4ef66e7c2dbfd91cb6ba7 OK
Cleaning up DB OK
However - all of those errors are nothing to do with LibreNMS, looks you’ve got or had another app installed with some php config. You’ll need to find that an clear it out.
I’m getting the following message
[librenms@librenms ~]$ ./daily.sh
fatal: unable to access ‘https://github.com/librenms/librenms.git/’: SSL certificate problem: certificate is not yet valid
Updating Composer packages OK
Cleaning up DB OK
Caching Mac OUI data OK
Check so the time is in sync on your server else you probably have a proxy that self-sign the certificates between your server and github.com, it’s not related to librenms tho. Talk with your network admin!
