I’m working on an AWS deployment of LibreNMS and would like to eliminate the manual step of having to run through the post-install screens for database setup and creating the admin user.
I’m assuming the admin user can just be inserted into the database manually.
Is there a script somewhere that I can run as the librenms user on the command line to automate the actual database creation step?
