I want to configure the Network map to see the Traffic(bit per second).
I edit config.php and print-map.inc.php but I didn’t find the solution to see the Traffic on the edge of th Network-map. Now I see the local_port on the edge.
‘label’=> ($local_port[‘ifName’]) . ’ > ’ . ($remote_port[‘ifName’]),
It is possible to see Traffic on the Network-map ?
What is the solution to see this on the edge ?
