Installing a new instance of LibreNMS today on CentOS 7 with the SNMP extensions. I have turned on the dhcp and ntp-client extensions.
First I had to doctor the dhcp script to look in the CentOS location for the leases file.
By default, I was getting this output:
[root@sentry2 snmp]# snmpwalk -v 2c -c public sentry NET-SNMP-EXTEND-MIB::nsExtendObjects
NET-SNMP-EXTEND-MIB::nsExtendNumEntries.0 = INTEGER: 2
NET-SNMP-EXTEND-MIB::nsExtendCommand."dhcpstats" = STRING: /etc/snmp/dhcp-status.sh
NET-SNMP-EXTEND-MIB::nsExtendCommand."ntp-client" = STRING: /etc/snmp/ntp-client.sh
NET-SNMP-EXTEND-MIB::nsExtendArgs."dhcpstats" = STRING:
NET-SNMP-EXTEND-MIB::nsExtendArgs."ntp-client" = STRING:
NET-SNMP-EXTEND-MIB::nsExtendInput."dhcpstats" = STRING:
NET-SNMP-EXTEND-MIB::nsExtendInput."ntp-client" = STRING:
NET-SNMP-EXTEND-MIB::nsExtendCacheTime."dhcpstats" = INTEGER: 5
NET-SNMP-EXTEND-MIB::nsExtendCacheTime."ntp-client" = INTEGER: 5
NET-SNMP-EXTEND-MIB::nsExtendExecType."dhcpstats" = INTEGER: exec(1)
NET-SNMP-EXTEND-MIB::nsExtendExecType."ntp-client" = INTEGER: exec(1)
NET-SNMP-EXTEND-MIB::nsExtendRunType."dhcpstats" = INTEGER: run-on-read(1)
NET-SNMP-EXTEND-MIB::nsExtendRunType."ntp-client" = INTEGER: run-on-read(1)
NET-SNMP-EXTEND-MIB::nsExtendStorage."dhcpstats" = INTEGER: permanent(4)
NET-SNMP-EXTEND-MIB::nsExtendStorage."ntp-client" = INTEGER: permanent(4)
NET-SNMP-EXTEND-MIB::nsExtendStatus."dhcpstats" = INTEGER: active(1)
NET-SNMP-EXTEND-MIB::nsExtendStatus."ntp-client" = INTEGER: active(1)
NET-SNMP-EXTEND-MIB::nsExtendOutput1Line."dhcpstats" = STRING: /usr/bin/cat: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutput1Line."ntp-client" = STRING: /etc/snmp/ntp-client.sh: line 20: cannot create temp file for here-document: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutputFull."dhcpstats" = STRING: /usr/bin/cat: /var/lib/dhcpd/dhcpd.leases: Permission denied
0
/usr/bin/grep: /var/lib/dhcpd/dhcpd.leases: Permission denied
0
0
0
0
0
0
0
0
0
NET-SNMP-EXTEND-MIB::nsExtendOutputFull."ntp-client" = STRING: /etc/snmp/ntp-client.sh: line 20: cannot create temp file for here-document: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutNumLines."dhcpstats" = INTEGER: 18
NET-SNMP-EXTEND-MIB::nsExtendOutNumLines."ntp-client" = INTEGER: 6
NET-SNMP-EXTEND-MIB::nsExtendResult."dhcpstats" = INTEGER: 0
NET-SNMP-EXTEND-MIB::nsExtendResult."ntp-client" = INTEGER: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".1 = STRING: /usr/bin/cat: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".2 = STRING: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".3 = STRING: /usr/bin/grep: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".4 = STRING: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".5 = STRING: /usr/bin/grep: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".6 = STRING: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".7 = STRING: /usr/bin/grep: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".8 = STRING: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".9 = STRING: /usr/bin/grep: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".10 = STRING: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".11 = STRING: /usr/bin/grep: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".12 = STRING: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".13 = STRING: /usr/bin/grep: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".14 = STRING: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".15 = STRING: /usr/bin/grep: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".16 = STRING: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".17 = STRING: /usr/bin/grep: /var/lib/dhcpd/dhcpd.leases: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."dhcpstats".18 = STRING: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine."ntp-client".1 = STRING: /etc/snmp/ntp-client.sh: line 20: cannot create temp file for here-document: Permission denied
NET-SNMP-EXTEND-MIB::nsExtendOutLine."ntp-client".2 = STRING:
NET-SNMP-EXTEND-MIB::nsExtendOutLine."ntp-client".3 = STRING:
NET-SNMP-EXTEND-MIB::nsExtendOutLine."ntp-client".4 = STRING:
NET-SNMP-EXTEND-MIB::nsExtendOutLine."ntp-client".5 = STRING:
NET-SNMP-EXTEND-MIB::nsExtendOutLine."ntp-client".6 = STRING:
After messing with permissions and trying to move things around, I twigged on SELinux, and after I issued
setenforce 0
…everything works properly.
So the question is – what is the correct course of action here? Is there a bug I should open somewhere? While I usually run computers without SElinux, I figure I should probably know how to live with it.
