I’m trying to work out if I’m misunderstanding things or if there’s a bug at work.
Have added a large number of cisco devices and almost all of them are alerting regularly on sensors being over or under limit.
None of the sensors values are anywhere near the high or low warning thresholds from the relevant Cisco Entity Mib, but they are exceeding the values show in the Device → Edit → Health page.
e.g.
A sample alert is:
#1: sensor_id => ‘4892’, sensor_oid => ‘.1.3.6.1.4.1.9.9.91.1.1.1.1.4.1338’, sensor_descr => 'Subslot 0/1 Transceiver 0 Tx Power ', sysObjectID => ‘enterprises.9.1.925’, sysDescr => ‘Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.4(3)S6a, RELEASE SOFTWARE (fc2) Technical Support: Support - Cisco Support and Downloads – Documentation, Tools, Cases - Cisco Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Tue 27-Sep-16 21:12 by mc’
Relevant capture from discovery.php:
entPhysicalDescr.1338 = subslot 0/1 transceiver 0 Tx Power Sensor
entPhysicalName.1338 = subslot 0/1 transceiver 0 Tx Power Sensor
entPhysicalClass.1338 = sensor
entPhysicalContainedIn.1338 = 1332
entPhysicalParentRelPos.1338 = 4
entSensorType.1338 = dBm
entSensorScale.1338 = units
entSensorValue.1338 = -24
entSensorMeasuredEntity.1338 = 0
entSensorPrecision.1338 = 1
entSensorThresholdSeverity.1338.1 = critical
entSensorThresholdSeverity.1338.2 = minor
entSensorThresholdSeverity.1338.3 = minor
entSensorThresholdSeverity.1338.4 = critical
entSensorThresholdRelation.1338.1 = greaterOrEqual
entSensorThresholdRelation.1338.2 = greaterOrEqual
entSensorThresholdRelation.1338.3 = lessOrEqual
entSensorThresholdRelation.1338.4 = lessOrEqual
entSensorThresholdValue.1338.1 = 20
entSensorThresholdValue.1338.2 = -10
entSensorThresholdValue.1338.3 = -73
entSensorThresholdValue.1338.4 = -103
[1338] => Array
[entSensorType] => dBm
[entSensorScale] => units
[entSensorValue] => -24
[entSensorMeasuredEntity] => 0
[entSensorPrecision] => 1
I see similar things for other devices and sensors. Every time I get an alert it’s within the entity-mib thresholds, but exceeds either the max or min value set in the device edit health page.
