Hello everyone,
I’m having a problem with the “Sensor under limit - Check Device Health Settings” alert for SFPs on FS.COM brand switches.
These alerts concern XCVR BIAS errors.
As you can see in the image below, the expected minimum value is 131.07, but the actual value displayed by LibreNMS is 0.13107. This seems to be an interpretation problem in LibreNMS, as the actual value is 131.07.
Note that the MIB correctly returns the correct value.
Do you have a solution to this problem?
Thanks in advance for your help!
