Hello Community
Trying to add the serial number and product type from R1500 HPE UPS in librenms.
In default, there is only the serial number from Network-MGMT Card.
In the mib there is a comment:
- cpqSiSysSerialNum (1.3.6.1.4.1.232.2.2.2.1) which is defined in CPQSINFO.MIB.
– This is the PDU/UPS serial number (listed but not implemented in SNMP Agent)
– cpqSiSysSerialNum OBJECT-TYPE
– SYNTAX DisplayString (SIZE (0…255))
– ACCESS read-only
– STATUS mandatory
– DESCRIPTION
– “The serial number of the PDU or UPS.
– The string will be empty if the system does not report the
– serial number.”
– ::= { cpqSiAsset 1 }
librenms/CPQPOWER-MIB at master · librenms/librenms · GitHub
The librenms read this snmp community.
Do you have any idea, how i can add this OID to these systems?
Regards Simon
