Service down does not affect host's availability
Hello everyone…
I just discovered the Librenms solution…
I configured a host with only monitoring of icmp and an http service.
But I notice that when the only http service is “down”, the host is always presented as “up”…
Did I miss something?
PS: I configured a critical alert using the proposed templates (services.service_status != 0)
Thank you in advance for your answers
availability only takes icmp/snmp availability into account.
The ability to account for service availability would be a new feature and need to be contributed by someone.
Thank you for your answer… that means that the host will still be “up” even if its services are down ?
Yes, the device is up, but the service is marked as down.
If you want to alert on service down, you do that directly. And it seems like you have done that.
Thanks, Murrant, for this explanations.
