Hi
After my last update [1.42.01-45-gbc5f01e - Sat Aug 18 2018 23:04:02 GMT+0530]
All my alert settings are gone, like my email settings are empty.
Also if i try to configure it again it is not getting saved, shows Error : NO CONFIG ITEM
Can Anyone help on this
Component |
Version |
LibreNMS |
1.42.01-47-g460d95e |
DB Schema |
258 |
PHP |
7.0.30-0ubuntu0.16.04.1 |
MySQL |
10.0.34-MariaDB-0ubuntu0.16.04.1 |
RRDTool |
1.5.5 |
SNMP |
NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.2
LibreNMS | 1.42.01-50-g7298c13
DB Schema | 258
PHP | 7.0.30-0ubuntu0.16.04.1
MySQL | 10.0.34-MariaDB-0ubuntu0.16.04.1
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[ WARN ] You have the old alerting system enabled - this is to be deprecated on the 1st of June 2015: https://groups.google.com/forum/#!topic/librenms-project/1llxos4m0p4
[ FAIL ] Discovery has not completed in the last 24 hours.
[ FIX ] Check the cron job to make sure it is running and using discovery-wrapper.py
laf
3
Hi
After the latest update the issue is resolved
