Sluggish web-ui and polling slowed down
[email protected]:~$ ./validate.php
LibreNMS 1.43-61-gc222d0e
DB Schema 267
PHP 7.0.30-0ubuntu0.16.04.1
MySQL 10.0.36-MariaDB-0ubuntu0.16.04.1
RRDTool 1.5.5
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.7.2
Since a day back the web-gui is extremely sluggish, every time I click myself to a new page the librenms.log is filled with thousands (14000 in one second) of logs like:
[2018-09-12 14:45:33] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:163 Illegal offset type
[2018-09-12 14:45:33] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:163 ksort() expects parameter 1 to be array, null given
[2018-09-12 14:45:33] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:162 Illegal offset type
[2018-09-12 14:45:33] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:162 ksort() expects parameter 1 to be array, null given
[2018-09-13 09:54:30] production.ERROR: 8 /opt/librenms/html/pages/front/tiles.php:35 Undefined offset: 1
[2018-09-13 09:54:30] production.ERROR: 8 /opt/librenms/html/pages/front/tiles.php:60 Undefined index: dashboard
Poller cpu increased about 10% since this, and it’s having trouble finishing its device polls.
Same problem here. Same errors in the log and I’m now getting un-polled device messages on the webui. The polling is finishing it’s just taking a lot linger to complete.
You are not alone. Seeing same thing in our /var/log/messages. Thousands of:
httpd-scl-wrapper: 2 /opt/librenms/LibreNMS/Component.php:162 Illegal offset type
httpd-scl-wrapper: 2 /opt/librenms/LibreNMS/Component.php:162 ksort() expects parameter 1 to be array, null given
Seeing similar issues here. Tons of these messages in the librenms.log file:
[2018-09-13 16:07:54] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:163 Illegal offset type
[2018-09-13 16:07:54] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:163 ksort() expects parameter 1 to be array, null given
Have tried solutions offered in the following but no luck yet:
Far as I can tell, the problem began with the update which switched to laravel. Here’s my ./validate.php output:
LibreNMS  | 1.43-61-gc222d0e
DB Schema | 267
PHP       | 7.0.31
MySQL     | 5.5.60-MariaDB
RRDTool   | 1.4.8
SNMP      | NET-SNMP 5.7.2
Same situation at my installation. After upgrade UI is not working at all. Show “Loading messages” at almost all pages and full of following log messages:
[2018-09-14 09:00:30] production.ERROR: 8 /opt/librenms/html/pages/devices.inc.php:76 Undefined index: to
[2018-09-14 09:00:30] production.ERROR: 8 /opt/librenms/html/pages/devices.inc.php:76 Undefined index: from
[2018-09-14 09:00:30] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:162 Illegal offset type
[2018-09-14 09:00:30] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:162 ksort() expects parameter 1 to be array, null given
[2018-09-14 09:00:30] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:163 Illegal offset type
[2018-09-14 09:00:30] production.ERROR: 2 /opt/librenms/LibreNMS/Component.php:163 ksort() expects parameter 1 to be array, null given
[2018-09-14 09:00:30] production.ERROR: 8 /opt/librenms/html/legacy_index.php:113 Undefined index: custom_css
[2018-09-14 09:00:30] production.ERROR: 8 /opt/librenms/html/legacy_index.php:271 Undefined variable: no_refresh
[email protected]:/opt/librenms# ./validate.php
LibreNMS 1.43-70-g9aa429c8d
DB Schema 267
PHP 7.2.7-0ubuntu0.18.04.2
MySQL 10.1.34-MariaDB-0ubuntu0.18.04.1
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
I am having similar issues. Keep getting the popup that says poller hasn’t completed in 5 minutes, tons of errors in the librenms.log especially when moving around the console. Started Tuesday. I built out a brand new install on Ubuntu 18.04 and it is doing the exact same thing. Could it be the change that was set to happen on the 11th?
You should all update and try again
Just updated, but situations stay the same:
LibreNMS 1.43-74-g4bd1f6711
DB Schema 267
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
I have updated several times manually with no resolution to the problem.
I had exactly the same issue.
At least I can confirm that these huge bloating of librenms.log is no longer occuring on my system.
LibreNMS 1.43-82-gcf31776
DB Schema 267
PHP 7.0.31
MySQL 5.5.60-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
Thank you!
-awaum
What did you do to solve your problem ?
The latest update, probably the “Component Errors” one, seemed to have done the trick.
Nothing by myself… ./daily.sh fixed it throughout the weekend…
I can confirm that errors in logs are missing with latest update, but UI still show me “Problem with backend”.
I can not find errors in any log, but this messages is still there. Also tried to clear the case and different browser but the same.
Could someone give me a hint how to solve the problem?
LibreNMS 1.43-82-gcf31776a6
DB Schema 267
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
I found the problem in my installation. Now everything is working as expected.
Thanks to all!
I can confirm that the Component.php ksort() errors are gone. Thanks!
LibreNMS  | 1.43-82-gcf31776
DB Schema | 267
PHP       | 7.0.31
RRDTool   | 1.4.8
What was your issue you fixed?
Initially when I tried to troubleshoot the problem I was added “#$config[‘secure_cookies’] = “true”;”
After removed it everything goes fine.
Well that’s a commented out piece of code so with or without it, nothing would have changed.
Actually was copy at the moment when was already commented. Before that it wasn’t commented.
Sorry for misunderstanding.
