after installing smokeping it does not start the web page giving the error 502 Bad Gateway (nginx/1.18.0 (Ubuntu)), but when I see the status of the service it is active and works normally, the log shows the error below;
smokeping.service - Latency Logging and Graphing System
Loaded: loaded (/lib/systemd/system/smokeping.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2022-10-25 11:50:40 WAT; 2s ago
Docs: man:smokeping(1)
file:/usr/share/doc/smokeping/examples/systemd/slave_mode.conf
Process: 1299547 ExecStart=/usr/sbin/smokeping --pid-dir=/run/smokeping (code=exited, status=0/SUCCESS)
Main PID: 1299584 (smokeping)
Tasks: 4 (limit: 77089)
Memory: 35.3M
CPU: 559ms
CGroup: /system.slice/smokeping.service
├─1299584 /usr/bin/perl /usr/sbin/smokeping --pid-dir=/run/smokeping
├─1299585 "/usr/sbin/smokeping [lnmsFPing-1]"
├─1299586 "/usr/sbin/smokeping [FPing]"
└─1299587 "/usr/sbin/smokeping [lnmsFPing-0]"
Oct 25 11:50:40 ubuntu smokeping[1299584]: No targets defined for probe lnmsFPing6-0, skipping.
Oct 25 11:50:40 ubuntu smokeping[1299585]: lnmsFPing-1: probing 25 targets with step 300 s and offset 4 s.
Oct 25 11:50:40 ubuntu smokeping[1299584]: Child process 1299586 started for probe FPing.
Oct 25 11:50:40 ubuntu smokeping[1299586]: FPing: probing 1 targets with step 300 s and offset 184 s.
Oct 25 11:50:40 ubuntu smokeping[1299584]: Child process 1299587 started for probe lnmsFPing-0.
Oct 25 11:50:40 ubuntu smokeping[1299584]: No targets defined for probe FPing6, skipping.
Oct 25 11:50:40 ubuntu smokeping[1299584]: No targets defined for probe lnmsFPing6-1, skipping.
Oct 25 11:50:40 ubuntu smokeping[1299584]: All probe processes started successfully.
Oct 25 11:50:40 ubuntu smokeping[1299587]: lnmsFPing-0: probing 25 targets with step 300 s and offset 233 s.
Oct 25 11:50:40 ubuntu systemd[1]: Started Latency Logging and Graphing System.
When validating libre I get the error below;
[FAIL] We have found some files that are owned by a different user than 'librenms', this will stop you updating automatically and / or rrd files being updated causing graphs to fail.
Files:
/opt/librenms/rrd/smokeping/__sortercache/data.FPing.storable
/opt/librenms/rrd/smokeping/__sortercache/data.lnmsFPing-0.storable
/opt/librenms/rrd/smokeping/__sortercache/data.lnmsFPing-1.storable
2022/10/25 11:46:33 [error] 1291689#1291689: *3 connect() to unix:/var/run/fcgiwrap.socket failed (111: Unknown error) while connecting to upstream, client: 10.6.6.22, server: librenms.mydomain.com, request: "GET /smokeping/ HTTP/1.1", upstream: "fastcgi://unix:/var/run/fcgiwrap.socket:", host: "librenms.mydomain.com", referrer: "http://librenms.mydomain.com/overview?dashboard=1"
after running the commands the errors disappear, but the Smokeping continues with the same error, if you restart the service the libre error appears again.
can anyone help?
Best Regards
| LibreNMS | 22.10.0-28-gbfc9c5f84 (2022-10-25T03:48:13+01:00) |
| DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (246) |
| PHP | 8.1.10 |
| Python | 3.10.6 |
| Database | MariaDB 10.6.7-MariaDB-2ubuntu1.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
