Hi, my path “/run/smokeping” keeps getting deleted after a few days; even if I grant or remove permissions, I have to create it every 4 days. Do you have any ideas?
That’s created by smokeping service and is removed by systemd if the service goes down. It should come back if you run systemctl start smokeping as root.
Check the /var/log/*.log for hints why it might crash.
