SMTP failing if SSL enabled
Hello all,
I can send email to an external SMTP server without encryption enabled.
If I enable SSL (supported by the SMTP server), then mail sending does not work.
From a packet capture, I can see a RST ACK sended by librenms… any idea why this is happening ?
Regards
