I am having an issue with SNMP and FreeBSD. Everything is working fine on a daily basis but every two weeks I get an alert SNMP Failed on all my FreeBSD vms (seems to be related only to FreeBSD, others are fine)
2 hours laters SNMP recovers itself. Alert logs below.
Where should I start looking for the cause?
ok 30.09.2019 22:55:45 x.x.68.122 SNMP check FAILED!
ok 30.09.2019 22:55:45 x.x.68.138 SNMP check FAILED!
ok 30.09.2019 22:55:44 x.x.68.42 SNMP check FAILED!
ok 30.09.2019 22:55:44 x.x.68.38 SNMP check FAILED!
ok 30.09.2019 22:55:44 x.x.68.6 SNMP check FAILED!
ok 30.09.2019 22:55:44 x.x.68.26 SNMP check FAILED!
ok 30.09.2019 22:55:43 x.x.68.46 SNMP check FAILED!
ok 30.09.2019 22:55:43 x.x.68.126 SNMP check FAILED!
ok 30.09.2019 22:55:43 x.x.68.206 SNMP check FAILED!
ok 30.09.2019 22:55:42 x.x.68.34 SNMP check FAILED!
ok 30.09.2019 22:55:42 x.x.68.114 SNMP check FAILED!
ok 30.09.2019 22:55:42 x.x.68.78 SNMP check FAILED!
ok 30.09.2019 22:55:42 x.x.68.98 SNMP check FAILED!
ok 30.09.2019 22:55:42 x.x.68.182 SNMP check FAILED!
ok 30.09.2019 22:55:42 x.x.68.118 SNMP check FAILED!
ok 30.09.2019 22:55:41 x.x.68.30 SNMP check FAILED!
ok 30.09.2019 22:55:41 x.x.68.74 SNMP check FAILED!
alert 30.09.2019 20:45:56 x.x.68.26 SNMP check FAILED!
alert 30.09.2019 20:45:56 x.x.68.138 SNMP check FAILED!
alert 30.09.2019 20:45:56 x.x.68.122 SNMP check FAILED!
alert 30.09.2019 20:45:55 x.x.68.118 SNMP check FAILED!
alert 30.09.2019 20:45:55 x.x.68.42 SNMP check FAILED!
alert 30.09.2019 20:45:55 x.x.68.126 SNMP check FAILED!
alert 30.09.2019 20:45:55 x.x.68.206 SNMP check FAILED!
alert 30.09.2019 20:45:55 x.x.68.6 SNMP check FAILED!
alert 30.09.2019 20:45:55 x.x.68.38 SNMP check FAILED!
alert 30.09.2019 20:45:54 x.x.68.182 SNMP check FAILED!
alert 30.09.2019 20:45:54 x.x.68.46 SNMP check FAILED!
alert 30.09.2019 20:45:54 x.x.68.114 SNMP check FAILED!
alert 30.09.2019 20:45:53 x.x.68.30 SNMP check FAILED!
alert 30.09.2019 20:45:53 x.x.68.74 SNMP check FAILED!
alert 30.09.2019 20:45:53 x.x.68.98 SNMP check FAILED!
alert 30.09.2019 20:45:53 x.x.68.34 SNMP check FAILED!
alert 30.09.2019 20:45:53 x.x.68.78 SNMP check FAILED!
ok 15.09.2019 22:30:48 x.x.68.122 SNMP check FAILED!
ok 15.09.2019 22:30:48 x.x.68.138 SNMP check FAILED!
ok 15.09.2019 22:30:48 x.x.68.42 SNMP check FAILED!
ok 15.09.2019 22:30:47 x.x.68.38 SNMP check FAILED!
ok 15.09.2019 22:30:47 x.x.68.6 SNMP check FAILED!
ok 15.09.2019 22:30:47 x.x.68.26 SNMP check FAILED!
ok 15.09.2019 22:30:47 x.x.68.46 SNMP check FAILED!
ok 15.09.2019 22:30:47 x.x.68.126 SNMP check FAILED!
ok 15.09.2019 22:30:46 x.x.68.206 SNMP check FAILED!
ok 15.09.2019 22:30:46 x.x.68.34 SNMP check FAILED!
ok 15.09.2019 22:30:46 x.x.68.114 SNMP check FAILED!
ok 15.09.2019 22:30:45 x.x.68.78 SNMP check FAILED!
ok 15.09.2019 22:30:45 x.x.68.98 SNMP check FAILED!
ok 15.09.2019 22:30:44 x.x.68.182 SNMP check FAILED!
ok 15.09.2019 22:30:44 x.x.68.118 SNMP check FAILED!
ok 15.09.2019 22:30:43 x.x.68.30 SNMP check FAILED!
alert 15.09.2019 20:20:55 x.x.68.74 SNMP check FAILED!
alert 15.09.2019 20:20:55 x.x.68.26 SNMP check FAILED!
alert 15.09.2019 20:20:55 x.x.68.138 SNMP check FAILED!
alert 15.09.2019 20:20:55 x.x.68.122 SNMP check FAILED!
alert 15.09.2019 20:20:55 x.x.68.118 SNMP check FAILED!
alert 15.09.2019 20:20:54 x.x.68.42 SNMP check FAILED!
alert 15.09.2019 20:20:54 x.x.68.126 SNMP check FAILED!
alert 15.09.2019 20:20:54 x.x.68.206 SNMP check FAILED!
alert 15.09.2019 20:20:54 x.x.68.6 SNMP check FAILED!
alert 15.09.2019 20:20:54 x.x.68.38 SNMP check FAILED!
alert 15.09.2019 20:20:54 x.x.68.182 SNMP check FAILED!
alert 15.09.2019 20:20:53 x.x.68.46 SNMP check FAILED!
alert 15.09.2019 20:20:53 x.x.68.114 SNMP check FAILED!
alert 15.09.2019 20:20:53 x.x.68.30 SNMP check FAILED!
alert 15.09.2019 20:20:53 x.x.68.74 SNMP check FAILED!
alert 15.09.2019 20:20:53 x.x.68.98 SNMP check FAILED!
alert 15.09.2019 20:20:53 x.x.68.34 SNMP check FAILED!
And before that it was 01.09.2019
LibreNMS | 1.56-3-g74724a461
DB Schema | 2019_09_29_114433_change_default_mempool_perc_warn_in_mempools_table (142)
PHP | 7.2.5-0ubuntu0.18.04.1
MySQL | 10.1.29-MariaDB-6
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.9.0
