SNMP error on Localhost
hi, i have a problem with localhost about snmp as this:
i checked the validate.php and everything in ok.
can anyone help what should i check and what is the solution?
check and see if snmp is running on localhost.
i do “service snmpd restart” and “systemctl enable snmpd.service” and snmpwalk command and it seems it should be ok.
ok check to make sure you have community string set in snmpd.conf
https://docs.librenms.org/Support/SNMP-Configuration-Examples/#operating-systems
i edited like this:
What is returned by systemctl status snmpd?
thanks, i solved it. it was because of snmp update.
