I was trying to perform install steps referenced for Ubuntu 24.04 but the snmp steps seems to of broken validation. The link to the steps is https://docs.librenms.org/Installation/Install-LibreNMS/#configure-snmpd but it seems to be broken when trying execut or access via a browser. Can someone verify if the curl step is broken? If it is broken please fix. When running the ./validation script I see a lot of errors like:
Cannot find module
Did not find
Unlinked OID
Cannot adopt OID
The install step that appears to be failing:
curl -o /usr/bin/distro https://raw.githubusercontent.com/librenms/librenms-agent/master/snmp/distro
Output reflects that it doesn’t include path /opt/librenms/mibs. Where is this snmp search path set?
Reported path: /home/librenms/.snmp/mibs:/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf
Cannot adopt OID in UCD-SNMP-MIB: laIndex ::= { laEntry 1 }
| LibreNMS | 24.11.0 (2024-11-20T08:58:54-06:00) |
| DB Schema | 2024_11_07_110342_custommap_edge_add_text_align (307) |
| PHP | 8.3.14 |
| Python | 3.12.7 |
| Database | MariaDB 11.4.3-MariaDB-1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.4.pre2 |
[OK] Composer Version: 2.8.3
MIB search path: /home/librenms/.snmp/mibs:/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf
Cannot find module (SNMPv2-MIB): At line 1 in (none)
Cannot find module (IF-MIB): At line 1 in (none)
Cannot find module (IP-MIB): At line 1 in (none)
Cannot find module (TCP-MIB): At line 1 in (none)
Cannot adopt OID in UCD-SNMP-MIB: laNames ::= { laEntry 2 }
[OK] No active python wrapper pollers found
