We are using InfluxDB for Grafana, but I can’t seem to find SNMP location (I want to use it for filtering). Is SNMP location also exported to InfluxDB, and if so, where should I find it?
Thanks!
Thanks!
You could add the LibreNMS MySQL database as a second data source in Grafana and then query against that for your hostname and location variables.
