I was looking at some of my (network) devices (MIB association tab) and found that there were no MIBs associated with them. In particular these are Cisco Small business switches. I was digging into this to find out why the box does not see some of the interesting data points which i’d expect to be exposed via SNMP (specifically temperature atm)
So I looked around a bit and found https://github.com/librenms/librenms/issues/3562.
Based on the info in there I ran a similar check and found that the new -IR switch seems to prevent snmptranslate to work properly…
./discovery.php -h ciscosg350xgk -d -m os
LibreNMS Discovery
SQL[SELECT version FROM dbSchema
ORDER BY version DESC LIMIT 1]
SQL[SELECT version()]
Version info:
Commit SHA: 07d07725954e6886c0723d234612c3f9bd447f61
Commit Date: 1532781837
DB Schema: 256
PHP: 7.0.30-0ubuntu0.16.04.1
MySQL: 10.0.34-MariaDB-0ubuntu0.16.04.1
RRDTool: 1.5.5
SNMP: NET-SNMP 5.7.3
Updating os_def.cache… Done
Override discovery modules: os
SQL[SELECT * FROM devices
WHERE disabled = 0 AND snmp_disable = 0 AND hostname
LIKE ‘ciscosg350xgk’ ORDER BY device_id DESC]
SQL[SELECT * FROM devices_attribs WHERE device_id
= ‘57’]
ciscosg350xgk 57 ciscosb SQL[INSERT INTO device_perf
(xmt
,rcv
,loss
,min
,max
,avg
,device_id
,timestamp
) VALUES (‘3’,‘3’,‘0’,‘1.05’,‘1.56’,‘1.23’,‘57’,NOW())]
SNMP Check response code: 0
SQL[SELECT attrib_value FROM devices_attribs WHERE device_id
= ‘57’ AND attrib_type
= ‘poll_mib’ ]
MIB: registering
Attempting to initialize OS: ciscosb
OS initilized as Generic
Modules status: Global+ OS Device
Load disco module core
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUQn -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/cisco udp:HOSTNAME:161 sysName.0 sysObjectID.0 sysDescr.0]
Expected LAST-UPDATED (SMI): At line 35 in /opt/librenms/mibs/cisco/SNMPv2-SMI.my
...0 = CISCOSG350XGK
...0 = ...*
...0 = SG350XG-2F10 12-Port 10G Stackable Managed Switch
Runtime for discovery module ‘core’: 0.0080 seconds with 1072 bytes
SNMP: [2/0.02s] MySQL: [8/0.00s] RRD: [0/0.00s]
Unload disco module core
Modules status: Global+ OS+ Device
Load disco module os
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovq -M /opt/librenms/mibs:/opt/librenms/mibs/cisco udp:HOSTNAME:161 SNMPv2-MIB::sysDescr.0]
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovqn -M /opt/librenms/mibs:/opt/librenms/mibs/cisco udp:HOSTNAME:161 SNMPv2-MIB::sysObjectID.0]
| SG350XG-2F10 12-Port 10G Stackable Managed Switch | .1.3.6.1.4.1.9.6.1.91.12.9 |
OS: Cisco Small Business (ciscosb)
Runtime for discovery module ‘os’: 0.0150 seconds with 1368 bytes
SNMP: [2/0.02s] MySQL: [0/0.00s] RRD: [0/0.00s]
Unload disco module os
= ‘poll_mib’ ]
= ‘poll_mib’ ]
MIB: registering
SNMP[snmptranslate -M /opt/librenms/mibs:/opt/librenms/mibs/cisco -IR -m all .1.3.6.1.4.1.9.6.1.91.12.9 2>/dev/null]
This doesn’t look like a MIB:
MIB: Could not find all::.1.3.6.1.4.1.9.6.1.91.12.9
SQL[UPDATE devices
set last_discovered
=NOW(),last_discovered_timetaken
=‘1.239’ WHERE device_id
= ‘57’]
Discovered in 1.239 seconds
SQL[INSERT INTO perf_times
(type
,doing
,start
,duration
,devices
,poller
) VALUES (‘discover’,‘ciscosg350xgk’,‘1532885768.4307’,‘1.368’,‘1’,‘LibreNMS’)]
./discovery.php ciscosg350xgk 2018-07-29 19:36:09 - 1 devices discovered in 1.368 secs
SNMP [4/0.03s]: Get[4/0.03s] Getnext[0/0.00s] Walk[0/0.00s]
MySQL [12/0.01s]: Cell[2/0.00s] Row[3/0.00s] Rows[4/0.00s] Column[0/0.00s] Update[1/0.00s] Insert[2/0.00s] Delete[0/0.00s]
RRD [0/0.00s]: Update[0/0.00s] Create [0/0.00s] Other[0/0.00s]
snmptranslate -M /opt/librenms/mibs:/opt/librenms/mibs/cisco -m all .1.3.6.1.4.1.9.6.1.91.12.9 2>/dev/null
CISCO-SMI::ciscoSB.91.12.9
./validate.php
Component | Version |
LibreNMS | 1.41-67-g58e331c |
DB Schema | 256 |
PHP | 7.0.30-0ubuntu0.16.04.1 |
MySQL | 10.0.34-MariaDB-0ubuntu0.16.04.1 |
RRDTool | 1.5.5 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.6.5
Is that a mistake on my side?
edit: sorry for the weird formatting, not sure how to clean that up
