I’m having trouble using snmp-scan to work, I can add host via gui without problem, but not via snmp-scan / autodiscovery. I have checked documentation a few times but so far everything seems correct.
It looks like snmp-scan is not using credentials from config.php. Debug on switch show that instead of authpriv i’m trying to use noauth
000366: Mar 27 16:59:02: v3 packet security model: v3 security level: noauth
000367: Mar 27 16:59:02: username:
extract from config.php
https://pastebin.com/Es5WzUAw
scnmp-scan error
https://pastebin.com/yjjU9KQt
| LibreNMS | c4672f8b37db261db287bba5985001b2ffc30f43 |
| DB Schema | 182 |
| PHP | 7.0.16 |
| MySQL | 5.5.52-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
Best regards,
Dawid
