one of my Systems (Storageserver) has a huge amount of Harddiscs which i monitor via SMART Application.
Also i drive a huge amount of Mdadm SW Raids which i monitor via Mdadm Application.
After reverse Engineering i found out SNMP seems to run into
“Timeout: No Response from ”
when returned String of SNMP Extend is above 1300 Bytes.
when reducing returned String, everything runs fine.
Does someone has a solution for this Problem?
E.g. increasing max Size of Extend String, or something like that?
thanks in advance
Sourcedoctor
