Hi guys,
I may have an issue that I am trying to solve regarding setting up an SNMP trap.
Our setup is in AWS (EC2 + RDS). I have followed the documentation when setting up snmp trap handler: SNMP Trap Handler - LibreNMS Docs
Following this documentation, I have set the following:
in /etc/snmp/snmptrapd.conf:
disableAuthorization yes
authCommunity log,execute,net CommStringHere
snmpTrapdAddr udp:162
logOption s
logOption f /var/log/snmptrap/snmptrap.log
traphandle default /opt/librenms/snmptrap.php
And I have followed Option 2 with exactly the same configuration as provided in the doc (Option 1 I have also tested on a different environment, no luck).
snmptrapd status is as follows:
● snmptrapd.service - Simple Network Management Protocol (SNMP) Trap Daemon.
Loaded: loaded (/lib/systemd/system/snmptrapd.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2024-05-09 11:26:26 UTC; 1 weeks 6 days ago
Main PID: 2712891 (snmptrapd)
Tasks: 1 (limit: 84237)
Memory: 2.9M
CGroup: /system.slice/snmptrapd.service
└─2712891 /usr/sbin/snmptrapd -f -m IF-MIB -M /opt/librenms/mibs -tLf /var/log/snmptrap/snmptrap.log
When started the service I have the following output in the log:
NET-SNMP version 5.8
When sending a trap from IPAM to the server I get no logs, however, tcpdump shows that the packet is being received, so the firewall rules and security groups are configured perfectly fine. I am also unable to get a log from a localhost.
Any ideas on how to solve this issue, please?
Thank you in advance.
Kind regards to you all!
