SNMP Traps with SNMP v3
LibreNMS 22.11.0-13-ga556aca1d (2022-12-08T00:41:06+00:00)
DB Schema 2022_09_03_091314_update_ports_adsl_table_with_defaults (248)
PHP 8.1.13
Python 3.7.15
Database MySQL 5.7.12-log
RRDTool 1.4.8
SNMP 5.7.2
[OK] Composer Version: 2.5.4
[OK]
[OK] MySQl and PHP time match
Modified Files:
includes/definitions/liebert.yaml
Do we have any guides on configuring SNMP Traps with SNMP V3?
Thanks!
LibreNMS doesn’t care. You need to setup the auth in your snmptrapd.conf as explained here: TUT:snmptrap SNMPv3 - Net-SNMP Wiki
Careful: Informs are easy but traps need a engineID form the trap source…
