I’m new to LibreNMS and I’m looking to monitor a device that uses SNMPv3 and requires the Engine ID be populated. I have found documentation that refers to Engine ID in device configuration, but not how to enter it in the “Add Device” forms.
Other monitoring tools I have used added the Engine ID to the user name field, is there a similar method here?
I understand that Engine ID is not widely used, but in this instance it is a requirement, at least for now.
Any help is appreciated.
